Capture issues, please help!!!
mosexclusive
Ok, here is my issue....I have a Canon XH-A1, and Premier Pro 2.0...I recorded some footage in 30F, 1080i....I downloaded the Canon HDV capture presets from Adobe, so I choose the appropriate preset to capture, and everytime I get the message "Capture device offline"....it still allows me to use the play controls, I just cant capture
Here's where I get confused....Premiere allows me to do a DV capture....It just says this when using HDV....I have tried everything I can think of to get this to work....I even downloaded the Cineform trial, and that wont detect the camera either....Ive restarted several times, checked every possible cable, made sure I had the settings on the camera right and everything checked out
Does anyone have any insight as to what could be causing this problem?
nevermind, fixed it....didnt know you had to set the playback options on the camera BEFORE connecting it via firewire....apparently some of the options get greyed out after connecting my cam
