Capture 24P & 60I in same Sequence?
ericcosh
I recently shot a wedding using 1 DVX100, 1 DVX100A & 1 PD150.
I used two Anamorphic Lens on the 100's and the wide mode on the PD150 which was a stationary camera.
During the ceremony, I used the 24P (standard mode) and during the reception, I switched to 60I.
My question is this. Can I just capture using the easy setup (NTSC DV Anamorphic) which is 29.97 and put all of them on the same sequence? In other words, I shot 24P and 60 I on the same tape. I'm capturing both of them together.
I know that if I shoot in 24PA, and then use the Advanced Pulldown that this is a different story, but if I just shoot and edit 29.97 regardless of using the 24P mode, is there any problem in this? The cadence should be the same right? 2:3:2:3?
Any help on this would be great.
thanks,
eric
Re: Capture 24P & 60I in same Sequence?
you CAN put 24P and 60i in the same sequence. I don't think you can put 24PA in the same. However you might have to edit the 24PA stuff in its own sequence then maybe copy the edited project over to the 60i sequence. I am not sure though.
