David Evans
Hi,
I'm having a problem with my Premiere CS4. I'm not sure this is normal, but when I apply a Time effect to a clip (let's say a slow mo with Frame Mix) and the clip already had a "Brightness and Contrast" option in there, the clip instantly looses the "brightness and contrast" effect. It only happens with that effect.
If I have the Fast Color Correction, I can use it with the Time effects at the same time. Any idea what could be wrong? This is a strong limitation, cause right now the only way I have to appy slow mo to a clip with "brightness and contrast" is to do it by changing the duration of the clip...
Thanks for any help
Thanks for any help
