I've been playing with the HVX's settings trying to test all the way to reduce the noise. I can't figure out if it's the settings or if I'm doing something wrong or if something might be faulty with my camera.
Yes, I've used the search and read every thread on the noise/gamma issues and have done many tests. The best combination that I have found for daytime, well lit shooting:
1080/30p
Shutter OFF
Gamma BPRESS
Detail Level -2
V Detail Level 0
Detail Coring +7
Master Ped -4
SKIN DTL On
Outdoor sunshine
ND 1/64
f4.0
The problem is I still seem to get noise in the dark areas. Also as soon as I decrease the exposure the noise just massively increases. I found that setting the iris between 2.6 and 5.6 seems to give the best result. This is actually one of the better examples. You can see the noise inside the room. The coring seems to 'blend it' quite well. If I was to decrease the detail coring, the noise would be much more sharp and defined sort of like the effect you get when you overdo Sharpen Mask in Photoshop.
You'll have to click on the thumb to open the link then click again on the image that opens to see the full res 1920x1080
The image was exported right from the MXF via Edius at 1920x1080.
1080/30p
Shutter OFF
Gamma BPRESS
Detail Level -2
V Detail Level 0
Detail Coring +7
Master Ped -4
SKIN DTL On
Outdoor sunshine
ND 1/64
f4.0
