Norm Sanders
Script Wrangler
I've tried linear, fast, slow, sharp, etc ... nothing gives a SAME speed/tempo the whole way through. In looking at the help, I understand that each one effects the pan in how it may curve around a corner or make it's path to the next point, etc.
BUT, I'm doing a LONG credit roll with a Photoshop file, and it starts out DOG slow, then picks up pace to where it's clipping along at a pretty fast rate in the middle then begins to slow down to that same dog's pace at the very end as it reaches the next/last keyframe.
I've only got two key frames ... one at the end, the other at the beginning. Both are set to linear with the other options (fast, sharp, smooth, etc.) just making it worse.
Suggestions? The only fix I can think of is to introduce a velocity envelope to it, but I'd think there's a better way to get key frames to behave the way you want them to.
