Hi all,
need some help here, will appreciate if you can give some advice
i have a g4 powerbook and g5 dual processor.
both are using fcp 5.1 crossgrade.
problem is that i cant capture to g5 dual processor.
it cant detect the firewire.
to my surprise, when i swap the firewire to my g4 15inch powerbook it capture well.
can somebody explain this to me.
is there something wrong with my g5.
i double check all the setting . seem to run perfectly fine.
the only dif, for my g5 when i bought was in os 10.3.9 than i upgrade to 10.4.6
in order to upgrade to fcp 5.1
right now, i am still troubleshooting the situation.
will appreciate if you can point out any web..
that will help me on this.
i try.
unplucking the firewire,
changing firewire cable.
restarting the g5.
restarting the deck.
hence, if you got any other information, pls let me know.
thanks
i try.
restarting the g5.
thanks
