Barry_Green said:If you're just starting out, it makes little sense to buy the most expensive camera. I mean, how much will "image quality" affect your results, vs. the sheer process of learning your skills?
If I were in your position I'd look at a used DVX100. You should be able to get it for under 2000 Euros, and really there's no reason to go spending five or six thousand on a camera that is most likely well above your skill level. Learn on the less expensive tool, and upgrade when your skills warrant upgrading. When you get to the point where the camera itself is limiting you, that's when you should look into upgrading. And, by that time, there may be many other, newer tools to choose from.
But this is the advice I'd give to anyone starting out -- don't overextend yourself at the beginning. Get something that does what you need, but I really don't see the rationale in spending twice as much when, in all likelihood, it'll be a year or two before you have developed your skillset to the point where any particular camera is limiting you.
