hey guys - im looking at the 35mm adapters - and have found that the canon FD lens are the easiest to come by (i have no lens at all so if u reckon something is better please say). only thing is i keep coming across threads that mention that he FD lens stay open until a 'shot' is taken (like when the pin is depressed or seomthing) - would this be an issue with the 35mm adapters - like does that mean u always have to shoot wide open?
Also when a lens says 1:1.8 it can be still be stopped down to close the iris further than 1.8 right?
EDIT
Ok i came across some info abt the canon lens - some have a 'hole' u have to stick a tooth pick sized device in and some look like this with a slide... http://www.letus35.com/type1.JPG
not sure if u can change apperture while hole is pushed in or the mechanism is slid...
so I guess the other Q is... would it be easier/better for me to go nikkon mount?
and
If i found an OLD camera with a FD or nikkon mount - would it be easy to swap with the current mount on a letus or sg35?
EDIT
and
