Cannot drag m2t file into Premiere pro 2
jin08611
Hey Guys
I have a problem I just go the Premiere pro after installing the software. When I open the problem I don't see the HDV folder as a present folder only see HD-SDI AJA, SD AJA, DV. How could I see the HDV folder in present folder? I cannot drag a m2t file into my Bin... I would get a error msg, saying that I cannot import it or wrong format! what should I do...
thank you
jin
You are using a trial version, right?
AFAIK, there is no HDV presets in the trial version thus lack of support for HDV footage. Sad but true.
/Roger
Averdahl -- Thank you so much for your info. I just download it last night to make sure I can use it for my editing...
Thank you for all your help!
Jin
You're welcome! :beer:
/Roger
I get the same problem. i am using premiere pro cs3. not the trial version. it does not recognize my m2t files. any suggestions?
