Cannot capture in Premiere
n1c02
For some reason now I cannot capture using Premiere. I am using a DVX100a
I used to be able to.. but it says to restart the camera ..
I did re install to see if that would remedy the problem with no luck. Has anyone else run into this problem. I am using Premiere CS3
Terry
Have you tried setting the Device control? Open the capture window and click the settings tab and choose DV/HDV Device Control.
Jun
Dvx
Dvx
I jsut went in an double checked. I set the DV/HDV Device control. The camera close to mine was the Panasonic AG-DVX100P.. mine is an A.
This did work for a while. But now all of the sudden it wont. I can capture in Vegas and other prgrams but in Premiere just stopped working
Still says
Can't Activate Recorder - Try Resetting Camera..
And I re-installed Premiere thinking this would fix it but still same problem.
is there something else I could try?
Terry
