Steve Laramie
Just wondering if a cinematographer will be smacked for calling cut if he botches a shot. Iv always let it run through incase there were some good moments.
ok. Is it really unproffessinal to botch small stuff with complicated shots. Ie crane dolly pan and have to land in a perfect frame and it ends up ending slightly off the planned frame will a director be pissed over that?
Killing a shot because in your opinion something could be batter, is the quickest way i know to get black listed.
work out a system with your director or first AD, like a hand signal for 'total failure'. i've seen the detrimental effects of actors being interrupted cold from a myriad of sources. minimize the potential for distraction.
firing a DP and dropping a unit is not the same thing, the DP is one man, who either works for the studio, or is an indi who is normally working with a rentle, while some DPs do run their own crew and equipment on every project they work on, most DPs are one man shows, who while they have people they like to work with, they are not his crew.
The DP does not have crew, every single crew member on set is part of the Director's crew
