Can vegas...
Re: Can vegas...
Yes. Assuming that you shot in DV in the first place, you would lose no quality and have the highest quality for a master version.
Vegas is capable of editing many different formats, but to output those you may need to have some sort of hardware board or something, I'm not sure. Hopefully Gary or Spot or David can weigh in with a more authoritative answer.
But if you shot on DV and are editing in DV, print back to DV tape and then take it to a dub house to get it output to some other format if you need some other format.
Re: Can vegas...
I bought a HD-SDI and a SD-SDI in/out card about a month ago.. and Sony has said it would add deck control for the card in upcoming versions, and deck control for the J3 HDcam decks.. but with the SD-SDI card you can output it to most SD decks.. and the cards come with an ap so you can also export Uncompressed Quicktimes from Vegas and shoot them them to HDCam or SD-Decks.
