Can Vegas display setting from DVX100A
djkoz
Is it possible to get Vegas to capture and display the settings that were used to film the clip with a DVX100A. It would be nice to have more information than just the field order, size, frame rate and aspect ratio.
It would be great to have data such as Chroma Level, Color Temp, Gamma, Date the footage was shot, etc.
Thanks for your help.
Dan K
You can see the date. The rest? I don't think the userbit info stream on the DVX is even detailed enough to store it.
Unfortunately, I do not see the original date. I see the Original Date column and the date original date does show up for still images in my Vegas library, but for video the Original date is blank.
Is there a setting I can change in Vegas or the DVX100A so that, at least, the original date will appear?
Thanks again.
Dan K
