Can this mixer/mic combo work somehow?
Nick Mirro
Hi. My first post here. Nice looking site :)
I'm new to professional sound (though not making any) and trying to put something together on a tiny budget. I'm hoping 2 affordable mics can be coaxed work with a mixer for field use. Will this inexpensive mixer work with the 2 mics below?
ROLLS MX124 PORTABLE 4 CHANNEL STEREO MIXER
Input Connections 4 - 3-pin XLR female
Output Connectors 2 - 3-pin XLR male
Max Input/Output Gain +55dB
Input Impedance: 600 Ohms
Output Impedance: XLR 500 Ohms
Signal-to-Noise Ratio 84dB
Phantom Power +18V DC
AC Power Requirements x2 9-Volt Alkaline Batteries
Current Draw: 30mA
Dimensions 6.3 x 2.3 x 3.7" (160 x 58.41 x 93.98mm) (WxHxD)
Weight 1.5 lbs (680.38 g)
AUDIO TECHNICA AT875
Transducer Fixed-charge back plate, permanently polarized condenser
Polar Pattern Line + gradient
Frequency Response 90Hz - 20,000Hz
Dynamic Range (Typical) 107 dB, 1 kHz at Max SPL
Sensitivity -30 dB (31.6 mV) re 1V at 1 Pa
Impedance 100 ohms
Signal-to-Noise Ratio RATIO 74 dB, 1 kHz at 1 Pa
Maximum Input Sound Level 127 dB SPL, 1 kHz at 1% T.H.D.
Power Requirements 11-52V DC, 2 mA typical
Output Impedance 100 ohms
Output Connectors Integral 3-pin XLRM-type
Phantom Power 11-52VDC, 2 mA typical
Dimensions 6.89" (175.0mm) Long
0.83" (21.0mm) Diameter
Weight 2.8 oz (80 g)
AND THE PROBLEM CHILD - Olympus ME51S Olympus ME-51S Stereo Microphone 145037 B&H Photo Video - already own this one.
(using a Y-adapter)
Type Stereo Electret Condenser Microphone
Frequency Response 100Hz - 15kHz
Directivity Uni-directional x 2
Sensitivity -40dB @ 1kHz
Impedance 2.2 kOhms
Plug 3.5mm Stereo
Power Supply Plug-in-power System (1.5V - 10V)
Dimensions (L x B x H)
1.5 x 0.55 x 1.6" (38 x 14 x 40mm)
Weight 0.24 oz (7 g), 0.6 oz (18 g) with cable and clip
Can these mic be coaxed to work with this mixer?
