ullanta said:Greetings, all, from a latecomer...
I have extensive experience in simultaneous recording a) to DVX/External mics and ProTools, b) to DVX/Line in and ProTools (from different preamps) and c) to DVX/Line in and ProTools (from the same preamps). This is primarily classical music, so demands may be higher than yours.
By far, the greatest distinction comes from bypassing the preamps of the DVX. They are pretty hissy in comparison to even low-end (but good) dedicated preamps.
Converter differences are comparatively minor, and for dialog likely completely irrelevant.
As for sample size, 16 vs. 24-bit - in most location settings, it really isn't likely to make a difference. If you're on a soundstage or in a studio, or micing things so close that ambient noise really drops away, yes; but for typical "DVX" situations, not a big factor. (Higher SAMPLE RATE - say 96K - has a greater effect, reducing high-end brittleness).
So, for most effective, inexpensive, and convenient sound improvement, go for the preamps...
-Barry
ElvisNTSC said:I do not use the sound of the DVX as a sound track because the internal mic records the cam noise. (It's worst when you play with the zoom control)l. Normally, I record the sound with a DAT and use the sound of the DVX as a sound reference (for the slate).
The sound recorded with the DVX is 16 bits (or 12 bits depend) and with the DAT, I can record at 24 bits, so the sound quality is better.
But, if you can't rent a DAT, the best if you rent a mixer (personnally, I use a Shure FP33) and you can control the sound.
ElvisNTSC
Dave_Fisk said:There is only one DAT machine that I know of that records 24 bit, and it's an expensive studio machine. There are no field DAT machines that record 24 bit, they are all 16 bit. Maximum resolution on a DAT machine is 48Khz, 16 bit. There is a noticable difference between 16 bit and 24 bit, namely dynamic range, and less crappy sounding high end, like silverware jingling together, and that sort of thing.
-Dave
tigeba said:All,
I can throw together a little shootout in my studio and post the results for all to hear. I would like your input on what combinations of things might be of interest. I was planning to test this anyway. I will use a Neumann KM84i as the source mic, since it is fairly close to a mic that would be used to capture dialog. Here were my thoughts on a few test setups.
1) KM84 -> mic pre on the DVX100a This would be the baseline setup
2) KM84 -> Neve 1272 Preamp -> DVX100a line in. This would emulate high quality external preamplification (like a field mixer) while using the recorder in the DVX.
3) KM84 -> Neve 1272 Preamp -> Digidesign HD192. Most people would probably consider this a high end external recording scenario.
I would note that it is fairly tricky to pull off these types of comparisons fairly as even small differences in output level can skew the perceived "quality" of the results. My prediction based on gut feeling is that the preamps may result in a noticable difference for some people, and that the differences in the recorder alone (DVX100a recording vs Protools HD recording) will not be that obvious. To keep things easy I will record the audio into Protools at 48/16. It is my opinion that 24 bit source for dialog will really not provide any distinguishable difference for this test.
