can someone identify the true difference in these kits?
Jonathan12uiz
I have been looking at these 2 kits and I don't really see the dimmer knob worth 100 more dollars for me, since I can switch off banks @ 25% each on both kits...
http://www.amazon.com/ePhoto-Daylig...=UTF8&coliid=I947P1YKYNGSJ&colid=KDQYJDTD5ITK
http://www.amazon.com/Dimmable-Vide...=UTF8&coliid=I3QBNG5XMZVOD&colid=KDQYJDTD5ITK
is there something that I don't know about the XLR type power? can someone please explain.
I really want an affordable LED kit that actually has the ability to be run off rechargeable batteries, so I can shoot on location without cords and extensions everywhere.
Well the Dimmable version has the same 4 Bank switches, but will also dim from 100% down to 10%, and can be run directly from a 12 volt source.
If you wanted to run the other model from a battery you would need an inverter.
All the Best!
Dave
All the Best!
Dave
ok so I can have a car battery on location an power them through that? but the dimable ones should still have a normal ac plug included right?
