Can someone explain the difference between these Logic FCP Key Caps?
But what would be in the upgrade? I cant find it anywhere.
I can't say for sure. The 13 keys in the upgrade basically turn the regular key set into the extended key set. I don't know what those 13 keys are, but they're basically an add on.
If you currently have a keyboard with no "shortcut keys" on it, then look into the full set you posted. The 13 key set won't help you.
i remember seeing a rubber overlay that you can put over the keyboard to learn
I prefer the actual keys instead as it keeps the keyboard feel.
