Before getting started you need to know that there is a potential of letting off some very dangerous dioxins with other toxic and potentially cancer causing gasses, so you must work in a well ventilated area and should wear a good respirator. Moreover, the result will not be as strong as it was before you made your changes.
When I dented my plastic sea kayak the manufacturer first recommended I try hot rags on the dent to draw it out, when that didn't work they told me to use a blow torch. Neither of these turned the concave into a convex but the kayak became very soft and malleable. So I would think if you had a basic form or jig that was the basic finished shape of the track you could easily bend it. Try a section. Good luck.
This idea seems somewhat plausible. Why not get a smaller piece of electrical pipe, slide it into the PVC pipe, plug up the ends (make sure to leave enough room for the PVC to get hitched), and THEN bend it with a standard pipe bender. They'd be a little heavier, but it seems like it would work. Hell, the weight may be a bonus feature; keeps the pipe ON THE GROUND!!!
Before you proceed you'll want to keep in mind that unless it is a long slow curve your dolly will not work - unless it is one of the smaller ones. The designed that I have seen and built have been the bigger dollies that allow someone to sit on them, and the wheels do not rotate. So tight turns would not be possible. If you have one of the designs that is just for your tripod you should be fine , probably ...
I know you want pvc, but consider this: try calling a local metal supplier and asking them if you purchased some metal tube if they would bend a couple pieces for you.
The worse thing they will tell you is no, but if they say yes you will enjoy it much better that warped pvc
