Yes.
We do this a lot in broadcast and it is useful if you need to cover two areas with the same transmitter.
Note it will not work the other way though and you can not use two transmitters with one receiver.
No problem at all, do it all the time. It can also give you a kind of spatial diversity that may improve the reliability of the system if you record both outputs and use the best one.
- Greg
If I've got 2 receivers set to the frequency of the 1 wireless transmitter will they both receive the signal clearly?
