Most DSLRs have manual mode in video, where one can set any shutter speed.
But video?As for cameras that can do it, a 200$ 550D + Magic Lantern can shoot down to 5 second exposure (0.something FPS). I use this for timelapse a lot.
The shutter speed cannot be lower than the frame rate. Physical impossibility. When you're taking 30 frames each second, each frame could only be exposed as long as 1/30 of a second, just common sense.
My GH1 only 1/30 in movie mode... a7rii can do 1/4. Any information on the RX10ii?In fact of the cameras I've tried this with the Canon DSLR's are the only ones that don't allow it. Any Sony mid-range video camera (NX5, NX3, FS700, EX1/3, etc) should do this with no problems.
So, if you want to shoot at a lower shutter speed, say 1/15, you would need to shoot at 15 frames per second. Want to shoot with a 1 second shutter speed, then you'd need a frame rate of 1.
When you shoot with a frame rate lower than 24, say 15, if you play it back at the same speed of 15, the video will look choppy, and if you play it at standard speed of 24/25p, the video will be sped up, like a timelapse.
That's not necessarily correct. Several cameras I've owned can record (say) a 1/15 shutter to a 1/30 video clip. The signal from the sensor is accumulated into buffer for the full 1/15s, then recorded as identical images on two successive frames.
Edit: I just checked and my Panasonic G7 does exactly this. I shot 1080p60 at 1/10sec - there resulting clip has sequences of 6 identical images (each with 1/10 motion blur) played back at 60fps.
Many video cameras will let you shoot at a lower shutter speed, and then the camera will just duplicate frames to fit the frame rate. So you end up with, for example, a 25p file where each exposure lasts for 5 frames.
Ebrahim's not wrong, and neither are you, you're just saying it differently. Ebrahim's exactly correct that you cannot have a shutter speed slower than the frame rate. And you're correct, the way the camera copes with that dichotomy is by buffering the frames. The result is duplicated frames, but at the frame rates that Ebrahim said. If you shoot at 1/2 second exposure, you cannot create more than 2 frames per second. If you record at 60p, you'll end up with (as you discovered) 30 identical frames in a row (29 duplicated frames for every unique frame). Which, in effect, is two distinct frames per second -- which is all the camera can create, when using a 1/2-second shutter speed.That's not necessarily correct. Several cameras I've owned can record (say) a 1/15 shutter to a 1/30 video clip. The signal from the sensor is accumulated into buffer for the full 1/15s, then recorded as identical images on two successive frames.
