camera movement with dvx help
willdvx
i have read that when using the dvx100 you always need to film with a tripod and be very smooth just like 35mm camera like they use in the movies. what problems would i have if used it handheld, also does the only apply when shooting 24p mode
many thanks
Depends what look you are going for POV, usually looks nice when done with a bit of Handheld, but if you are going for the pro look, steady shots can only be achieved when the camera has a support system, eg. Tripod, crane, dolly, sand bag, etc...
- Derrick
You can also get away with some very controlled hand held movement and then stabilize the footage using tracking in After Effects. It's not ideal as you loose a little res (very little actually) but it can work quite well when you don't have any other options and need smooth camera movement.
if ur trying to understand something u read somewhere, then I'm guessing they were discussing the "strobing" effect which takes place when u pan or tilt quickly while shooting 24 frames a second.
A lot has been writting about this subject but really, shoot stuff in 24p and if the quick pans look weird to u, investigate the subject more, if u cant really tell, dont worry about it and shoot more.
