rook said:This is very cool.
Smart thinking.
Now who can give me the short answer on how you can compress without losing resolution?
-rook
x-angel said:my question is why did they do a USB connection when they probably could have gotten better results with Firewire
There are lossless compression schemes, they're just not very compressed is all. Most video compression schemes deliver incredible file-size reductions; a 25-megabit HDV stream is turning a 186-megabyte-per-second raw source data stream (1920x1080x24bppx29.97fps) into a 3.1-megabyte-per-second compressed data stream. That's compression of about 60:1. With lossless you're looking at more like 1.3:1. Not anywhere near the same ballpark, and obviously of very limited usefulness. Lossless may mean the difference between needing an 8-drive SATA RAID and needing a 5-drive SATA RAID, but lossy compression means the difference between needing an 8-drive SATA RAID and needing a $4 tape.rook said:But while we are at it...how can you compress without losing res? I can't seem to bend my head around it.
