Burining HD DVD from Final Cut Pro
KingsReign
I have a Toshiba HD DVD player and want to export a 720P sequence from Final Cut. I know you have to use the MPEG-2 setting with AIFF audio to get the HD DVD to play on the Toshiba correctly, but my problem occurs once I am in DVD Studio Pro 4.
The files simulate fine in the player, but when I try to build/burn the disc, I get an error about the Muxing Bit Rate being too high and does not burn. Can anyone help me out. I am using the default HD DVD - MPEG 2 setting from compressor.
No, you can burn the disc (as I have and it worked great). The problem is that only the video file can be burned by itself. When I add the audio to the track, then the Muxed Data Rate gets too high. I don't know how to fix that.
are you using AIFF for the audio? that may be why your data rate gets too high... use the dolby 2.0 settings in compressor for audio.
