ok i've been playing around with making my own dollies with rollerblade wheels and i've finally come to the conclusion that the skateboard wheels just make more sense.
the rollerblade wheels are contantly fighting the stress of the weight that tries to spread the wheels farther apart.
when you buy the quality rollerblade wheels and some decent nuts and bolts your right up to the price of what a decent pre-made set of skateboard dolly wheels/trucks would have cost you.
so here are the two i'm considering...
http://www.willyswidgets.com/pr_wheels.html
http://dvmoves.com/products/dolly/index.cfm
the dvmoves model is less expensive for the four wheel per truck version than the willy's widgets model.
the willy's model has its own frame of sorts that connects the two trucks on each end of the plywood.
i have the willy's widgets pvc connectors and they are made quite well but the dvmoves skateboard trucks look like they might be better made than the willy's widget one.
willy only shows you line drawings so its hard to compare some of the info.
i'm starting the next short july 25th so this week is my deadline for having all things i need to build done with.
so i basically need to order the skateboard wheel system i choose today or tomorrow and i need some last minute feedback.
matthew
matthew
