mentatDUKE
Hello all. I plan on building a daylight balanced china ball system with an eye toward high lumen output and a soft light quality.
With this in mind, I plan on using a heavy duty compact fluorescent (12,000 lumens, 800W equivalent) and a large china ball (30 inches most likely), the bigger the source, the softer the light.
If any of you have used china balls in the past, how do you go about placing them in a scene when shooting on location? Do you hang them from the ceiling (if it isnt too high) or do you use light stands?
Here's the compact fluorescent I have my eye on:
http://www.lightbulbemporium.com/maxlite_35871_ml_sko200ea50.asp
Here is the china ball I want to use:
http://www.asianideas.com/whnyla.html
Looks like a standard bulb assembly wont cut it. The bulb I want has a base type of E39 Mogul.
I may have to get this power cord rather than the assembly from the first post:
http://www.specialty-lights.com/903064.html
