Randall_Oelerich
SOLVED: Tagger did not seem to like Medium (125%) font display on my Windows 7 HD 1920x1020 screen resolution. Tagger works fine at small default 100% setting, or large 150% setting (what I plan to use now whenever i use Tagger).
I am learning to use Final Draft Tagger (latest version 2, downloaded this morning) so I can mark up a .fdx with chars/props/etc for scenes, to then import into Gorilla 5 for film scheduling, breakdowns, etc. But as I look at the action text in Tagger, there are entire lines of action missing, or sometimes a line of action text only shows the upper half of the font text. Anybody else have this happening, or could someone check to see if this is also the case on your PC? Wondering what I might be doing wrong, if anything. I am using Final Drat 8, Final Draft Tagger 2. I have tried changing the Final Draft script font from the default font to Movie Magic Screenwriter font or vice versa, but that does not solve the issue. I tried dropping my screen resolution from 1920x1080 to a lower res but that had no effect on the problem. If I can't see all the lines/words in a final draft screenplay (.fdx) I can't really properly mark up material in Tagger to create a proper .sex file for importing to a scheduling/breakdown software program (e.g. Gorilla).
