Broken timecode and capturing...
kylelewis1
I have a tape that I am wanting to capture on FCP which someone else made. However, they completely messed up the timecode so there are gaps where the numbers restart. Is there anything I can do that will go through the tape and change the numbers without changing what was videotaped? Or, is there a way FCP can capture it without having a hissie fit every time the timecode is broken (and then redo the timecode)?
Thanks! :D
Re: Broken timecode and capturing...
[quote author=Kyle_of_Maryland link=board=FCP;num=1090128684;start=0#0 date=07/17/04 at 22:31:24]I have a tape that I am wanting to capture on FCP which someone else made. However, they completely messed up the timecode so there are gaps where the numbers restart. Is there anything I can do that will go through the tape and change the numbers without changing what was videotaped? Or, is there a way FCP can capture it without having a hissie fit every time the timecode is broken (and then redo the timecode)?
Thanks!  :D[/quote]
FCP4 and better can capture over gaps. If the TC runs all over the place, use the "capture now" feature and just dump the attempts to capture in batch.
I would get a second camera or deck, and a 4-4 pin firewire cable, and clone the tape with brand new timecode. At least you will be able to re-capture if you ever have a hard drive crash or something.
Thanks!  :D[/quote]
FCP4 can do this without breaking a sweat... set your preferences to make a new clip each time.
[quote author=Mitch_Ives link=board=FCP;num=1090128684;start=0#3 date=07/18/04 at 11:42:58]
FCP4 can do this without breaking a sweat... set your preferences to make a new clip each time.[/quote]
Where do I go to set the preferences for capturing? Is it where the preferences for the other general stuff or is it another place?
I found it. It is in File, preferences, and then on that first page of stuff. Thanks!
