Broken DVXuser battery - help!
emccainaz
Hi,
I dropped my DVXuser 5600 battery and the case cracked to bits. The battery pack and
chip seem fine. I tried contacting the email address where I purchased it, but got no repsonse, so is there any way to salvage a perfect battery that just needs the case?
Thanks,
Edward McCain
It depends on how small the piece are and how many, but superglue might do the trick. If it's really that bad, you might try to fix it with fiberglass.
I can't fix it with glue or fiberglass because I have to have the battery contact pins align perfectly with the DVX contacts. If I could get an empty case from the place that sells the batteries, that might work, but I can't get a response from them so far.
Edward
