i am trying to make a flat medium gray picture to turn softly into white in about 20 seconds.
i have tried to use levels adjusting the gamma to do this. when i preview the effect it looks good. each pic is turning lighter and lighter evenly, but when i render it and play back in real time, it looks bad.
the first pic looks ok and then as it turns lighter, gray horisontal lines appears on the surface until it goes white. at first the lines have higher density and later it becomes wider soft gray lines until it goes white.
why cant i get an even change?
i have also tried with colorcorrector and different blur filters to repair the lines, but the same thing appears...
hope someone can help.
thanx
teupaksa
thanx
teupaksa
