Brevis non-flipped 72mm?
Hello everyone!
I have finally decided to go ahead and purchase a Brevis 35mm adapter for my HPX-170! I'm going to be buying the non-flipped version considering the HPX has the built in image flip option and i dont mind adjusting it in post. :) My question is, do I need any step up or step down rings from cinevate when i purchase the bundle? From what I understand the Brevis has 72mm threads on it as well does the HPX.
Also, on a bit of a side note, I'm looking for an inexpensive follow focus system that will work with Canon EF lenses. If any one knows where i might find one that would be a big help!
Thanks so much,
-Christopher
If the HPX has 72mm threads as you say then you wont need any step up or step down rings as the brevis is 72mm as well. But you will most likely need a "spacer ring" if your buying the non flip module. It only about $20 extra.
Have fun with it I just got mine delivered yesterday :)
