BRAW in FCPX? BRAW Toolbox?
ahalpert
Major Contributor
I'm receiving footage shot in BRAW. Is it a bad idea to work with it in FCPX? Will BRAW Toolbox do the trick? Are there downsides? Is there a better option? Or should I just use Resolve?
BRAW toolbox works. It doesn't behave in the manner that other formats do on import. It essentially creates and event to put all your BRAW into and then nests the audio to the video. So if you want to make raw adjustments you have to drilldown into the file the same way you would with a compound clip.
I'm not sure if I'm describing it right but if you're used to FCPx Braw toolbox is worth utilizing
