In boujou you can create poly masks to isolate the hand/arm from the rest of the scene.
I'd try that first, maybe leave some edge around the hand so that there is some contrast between it and the background. Then track it and see if your getting enough targets to solve it. If not you may have to manually add some targets by hand to help it along.
Thanks Raptor, i think that this is a good solution!, because i dont want to paint dots in the hand, that is good for test, but i dont think is quite good if the dots shows in the final render.
i will try adding targets too, thanks again !.
