DammitJanet
Has anyone had any success using the Blue Ball mic for typical boom/filmmaking purposes? I know it seems a bit unorthodox, but I was just wondering if anyone's ever tried it and had good results. Thanks.
ullanta said:I've got Blue Balls and 8-Balls. And basically, the answer is NO, for 2 reasons:
1) They're both designed to sound best pretty close to a source, and neither has as much reach as you'd like for a boom mic. They're also both fairly wide cardioids, so have a little less directionality than you'd like.
2) They're a little heavy and unwieldy for boom work. And the shockmount (The Ringer) is absolutely huge. And it's hard to get the Ringer/Ball combination tightened down enough in stable use; I imagine it would always be in danger of flopping around on a boom. If you can even find a beefy enough operator to hold the heavy combination up...
Exactly right. I bought a Blue Ball for the novelty value, but ended up eBaying it within a year.
And the Ringer has to be seen to be believed! It's roughly the size of a microwave pizza!
David Kuznicki
Production Manager, WGTE-TV30
