I'm looking to get an on-camera light but I don't want to have my subjects look like they're in the front of a photon cannon. Does anyone have any suggestions on how to use an on-camera joint without it looking like an episode of COPS? 8)
Is this for narrative work, or documentaries? If it's for narratives, I'd suggest against the use of an on camera light altogether...
If you're doing live work (bar mitzvahs, documentaries, etc) and you have to, it'll still look like "cops", but it'll be more acceptable. But if you're making a feature, it *will* look cheesey. Best thing I'd suggest is to diffuse the light, get a soft box or something to the like, to make sure that there's as soft a light as possible. This'll make it less noticeable...
I've never used those lights before... but I have seen how bright and ugly they can be. I would try and bring it down as many stops as I can and just use it as an eye light... which would look great.
As Mike said, the first thing towards reducing the "deer in the headlights" look is to get a decent soft box. PhotoFlex makes a 5" x 7" softbox for on-camera lights. But if you're shooting through a softbox, you'll need a fairly powerful light -- probably at least 75 watts, preferably 100.
Second thing to do, if at all possible, is get the light off-axis. Blaring light directly from the camera will be the least flattering. Move it over to the side so it angles onto your subject and it'll look much better.
[quote author=Barry_Green link=board=lighting;num=1089130032;start=0#3 date=07/06/04 at 10:45:04]As Mike said, the first thing towards reducing the "deer in the headlights" look is to get a decent soft box. PhotoFlex makes a 5" x 7" softbox for on-camera lights. But if you're shooting through a softbox, you'll need a fairly powerful light -- probably at least 75 watts, preferably 100.
Second thing to do, if at all possible, is get the light off-axis. Blaring light directly from the camera will be the least flattering. Move it over to the side so it angles onto your subject and it'll look much better.[/quote]
Very good advice. I didn't even know they made softbox's for on camera lights. I agree with turning the light off-axis as well. A stright on flat light looks horrid unless thats the effect your looking for... then it looks great
Depending on the type of light it is there are several options.
1. Use a low wattage bulb
2. Anton Bauer makes little small Softboxes for their ultralight on board camera lights.
3. some companies have barn doors on their lights
4. You can go a step further with the barn doors and clip a half sheet of diffusion onto the light.
Kino Flow makes a RING LITE (not sure on official name) but its a soft light that you attach around the lens of the camera. A friend of mine told me he saw a Network Photographer with one on his ENG camera and he said the reporter was lit very nicely. It wasn't to bright or to soft...however B&H has this light for about $495
Thanks guys, this helps a lot. I'm shooting a documentary so I think I'll go with the on-cam soft box. So far I've been checking out the Cool lux SL3000
[quote author=Speezy link=board=lighting;num=1089130032;start=0#0 date=07/06/04 at 09:07:12]I'm looking to get an on-camera light but I don't want to have my subjects look like they're in the front of a photon cannon. Does anyone have any suggestions on how to use an on-camera joint without it looking like an episode of COPS? 8)[/quote]
Well . . .
They ARE, quite literally, in front of a "photon cannon" when they're in front of any light . . .
[quote author=Speezy link=board=lighting;num=1089130032;start=0#9 date=07/07/04 at 10:33:46]Ok folks, I just picked up the Cool Lux SL3000. I'll let cha know how it works out.[/quote]
Well, I've been playing around with the Cool Lux and it's looking good so far. My only question is this, it came with a cable i assume plugs into a power source. Being that the plug is 4 prong, what in the world do I plug it into if I don't want to use a DC adapter? Must I have a power belt? There's got to be another method. Anyone care to enlighten a newbie?
