Blackmagic mini converter, black and white??
m.salah
Hi,
I am using a Blackmagic ATEM Television Studio switcher to broadcast on the Slingbox Pro-HD. So I have purchased a Blackmagic SDI to Analog mini converter, so the Slingbox device can read the images+audio. I am using a composite video cable and connecting it from the output of the mini converter and send it to the composite input of the Slingbox. But my issue is that I only see black and white images. Can anyone help?
I did try to use a component cable and connected it to the Blackmagic converter output and to the component inputs of the Slingbox device. but no video was showing.
If you connect only the composite from the "Y" of a component connection, you get a B&W signal. Make sure that you have the mini converter set up to output a true composite signal. Assuming it can be set up to do that.
