If you only need HDMI I/O then you don't need the Pro. But if you want/need analog I/O then you should get the Pro. For example, in your case I'm not sure how you'd hook up an SD monitor if you only had HDMI I/O.Nice. I'm looking at this card as well - is the difference between the regular version & pro worth it? I found some regular versions for super cheap on ebay but if the pro is definitely worth the extra $$ then I'll find a way to get it.
