Blackmagic Design announces PL lens mount camera models
KerryLamond
IBC 2014, Amsterdam, The Netherlands - September 12, 2014 - Blackmagic Design today announced the immediate availability of two new cinema cameras, the Blackmagic Production Camera 4K PL and Blackmagic Cinema Camera PL. Both cameras now include PL mount models for using professional cinema lenses or even vintage cinema lenses and are now available from $2,295.
Blackmagic Production Camera 4K PL and Blackmagic Cinema Camera PL will be demonstrated on the Blackmagic Design IBC 2014 booth in Hall 7, Stand H20.
The new PL lens mount options for the classic Blackmagic Cinema Camera design now provides customers with an extremely small and extremely strong design. The strength comes from the chassis which is machined out of a solid block of aluminum. With the combination of the PL lens mount, the whole camera design has enough strength to hold an extremely heavy PL mount lens. This means cinematographers now have a professional PL mount digital film camera that’s so small, the camera body is only a little larger than the lens mount itself. Customers then get a design that can fit into the tightest locations while still allowing decades of classic professional film lenses to be used.
With these 2 new PL mount models, Blackmagic Design customers can now choose from 5 separate variations of this small, tough design. With a combination of 2 different sensor types as well as 3 different lens mounts, customers can now simply select the features they need based on the work they do.
The Blackmagic Production Camera 4K PL gives you a high resolution Super 35mm size sensor with global shutter and a more creative depth of field. Customers get incredible Ultra HD images with 12 stops of dynamic range and a large sensor with minimal crop factor so they can capture amazing wide angle, feature film quality shots. When working in HD, customers can use the high resolution images to reframe and zoom into shots without any quality loss.
The Blackmagic Cinema Camera PL has a 2.5K sensor with a super wide 13 stops of dynamic range that delivers truly cinematic quality images. Both cameras have dramatically wider dynamic range than traditional video cameras that preserves more detail in the blacks and whites of an image. For example, customers can shoot indoors with the correct exposure and still get full detail through windows outside. Every detail captured by the cameras’ sensors is preserved in the RAW files and can be edited and grade natively using the included DaVinci Resolve software for the highest possible quality output!
Both cameras capture CinemaDNG RAW and ProRes files using the built in high speed SSD recorder. Once the shot has wrapped, the disk can be connected to a computer for editing or color correcting straight from the disk using DaVinci Resolve, Final Cut Pro X, Media Composer, or Premiere Pro CC. Working with CinemaDNG RAW preserves the wide dynamic range of the files, allowing customers to open them directly in DaVinci Resolve 11 for editing and grading at the highest quality. That means the final output from DaVinci Resolve is literally a first generation render from the camera original RAW files!
The Blackmagic Production Camera 4K PL and Cinema Camera PL have been designed with portability and durability in mind. They include standard connections so customers do not need to hunt for custom cables, an internal battery, a high resolution 5” LCD touchscreen viewfinder that can be used for entering metadata and that shows settings such as shutter speed, color temperature, timecode and more. Both cameras feature professional SDI connections, built-in Thunderbolt, 1/4” audio jacks for mic/line inputs, 12V to 30V DC input, a 3.5mm headphone socket and LANC for remote control. Blackmagic Cinema Cameras are true digital film cameras that you can hold in your hand, but with the strength to be rigged on cranes, used on Steadycams, in crash cars and more.
“Since the launch of the first Blackmagic Cinema Camera, customers have been asking us for a solution that works with PL cinema lenses. What people don’t know is that when we were originally designing the Cinema Camera, we were designing it as PL mount. But we quickly realized that allowing it to work with photographic lenses was important, so we changed to the EF lens mount for Canon lens compatibility. But you can see from the design of the solid metal chassis, that the camera was way over engineered for the EF lens mount. Now the PL lens mount is completed it’s easy to see what a great combination this strong chassis and the PL mount are. It’s the perfect balance and it’s so strong!” said Grant Petty, CEO, Blackmagic Design. “What’s also exciting, is the PL mount lets cinematographers add classic PL mount lenses. That means if you want to shoot something from the 1980s, then you can just choose the lens they used in the 1980’s and shoot with it. There are so many different kinds of classic cinema lenses out there with all types of glass, materials and coatings that the looks are endless. All those can now be used on these new cameras!”
[h=3]Blackmagic Production Camera 4K Key Features[/h]
  • Production Camera 4K PL features a large, high resolution 4K Super 35mm sized sensor with global shutter with 12 stops of dynamic range.
  • Cinema Camera PL features a large, high resolution 2.5K sized sensor with 13 stops of dynamic range
  • Compatible with extremely high quality PL cinema lenses.
  • Built in SSD recorder allows long duration recording onto solid state disks.
  • CinemaDNG RAW and ProRes open file formats compatible with DaVinci Resolve, Final Cut Pro X, Media Composer and Premiere Pro CC. No custom file formats.
  • Blackmagic Cinema Camera also records in DNxHD.
  • Features all standard connections, including jack mic/line audio in, headphone mini jack, Thunderbolt, LANC remote control and standard 12V DC power connection. Blackmagic Cinema Camera supports 3G-SDI output for monitoring with camera status graphic overlay, and Blackmagic Production Camera
  • Built in touch screen LCD for camera settings and metadata entry compatible with popular video editing software including DaVinci Resolve 11 and Final Cut Pro X
  • Blackmagic Production Camera 4K supports 1080HD and Ultra HD, and Blackmagic Cinema Camera supports 1080HD capture, both at 23.98, 24, 25, 29.97 and 30fps.
  • Mounting points on top and bottom for connecting tripods, accessories and building custom rigs using industry standard equipment.
  • Includes UltraScope software for live scopes via the built in Thunderbolt connection.
  • Includes the full version of DaVinci Resolve 11 editing and color grading software.
[h=3]Availability and Price[/h] Blackmagic Production Camera 4K PL is available now for US$2,995 and Blackmagic Cinema Camera PL is available now for US$2,295 from Blackmagic Design resellers worldwide.
[h=3]Press Photography[/h] Product photos of the Blackmagic Production Camera 4K PL, Blackmagic Cinema Camera PL and all other Blackmagic Design products, are available at www.blackmagicdesign.com.
[h=3]About Blackmagic Design[/h] Blackmagic Design creates the world’s highest quality video editing products, digital film cameras, color correctors, video converters, video monitoring, routers, live production switchers, disk recorders, waveform monitors and real time film scanners for the feature film, post production and television broadcast industries. Blackmagic Design’s DeckLink capture cards launched a revolution in quality and affordability in post production, while the company’s Emmy™ award winning DaVinci color correction products have dominated the television and film industry since 1984. Blackmagic Design continues ground breaking innovations including 6G-SDI and 12G-SDI products and stereoscopic 3D and Ultra HD workflows. Founded by world leading post production editors and engineers, Blackmagic Design has offices in the USA, UK, Japan, Singapore and Australia. For more information, please go to www.blackmagicdesign.com.
