Blackmagic Decklink Extreme HD..anyone?
take2visualmedia
Does anyone here use the Blackmagic Decklink Extreme HD? I just bought one, should be here tomorrow. I need a good way to get quality video to my BetaSP deck for broadcast and I liked the HDMI I/O that decklink offers.
Anything I should watch out for before I set this up?
It's dope but best to ask after you have a chance to play with it. If you're planning to try uncompressed HD or a lot of ProRes HQ, it's worth stepping up to a fast RAID.
-Noah
hi, sorry to resurrect this dead thread, but i have a question about a decklink hd extreme that i'm bidding on on eBay.
the current bid is $500, and I placed that before realizing that there was a model of the decklink extreme HD that did not have HDMI. unfortunately, i'm bidding on that model. the good news is that I don't need it because I don't have a TV with HDMI or a camera that outputs through it. the description said to get specs from the blackmagic web site, and the HDMI model is the only HD extreme they have any information about.
my question is whether or not this card is still going to be worth $500 or if i should try to retract my bid.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MEWAX:IT&item=150326425748
[FONT=Arial, Helvetica, sans-serif]Card in new and in the original box. Box was opened but item never used. DeckLink HD Extreme is the first DeckLink card to feature both SDI and analog I/O connections that instantly switch between high definition and standard definition video. Use with the latest PCI Express Mac and Windows computers for the world’s highest quality editing, effects and broadcast paint solution. The highest quality HD/SD switchable PCIe video card with SDI and analog connections. Features: - Connections: SD/HD-SLI in, 2 x SD/HD-SDI out, YUV/NTSC/Pal/S-video in and out, YUV operates in HD or SD, 2 channel XLR audio in and out, AES unbalanced audio in and out, RS-422 Deck Control and Reference in. - Real time effects supported in Apple Final Cut Pro HD and Adobe Premiere Pro - True 10 bit and 8 bit uncompressed YUV video capture and playback for high-end production quality. - Compressed video capture and playback on supported platforms. Edit in DV, JPEG, HDV and DVCPRO-100HD files on Mac OSX - Blackmagic Deck Control included – complete solution for automated capture and playback of media to broadcast tape decks using serial control. - Video Desktop for video output from non video software. True computer monitor display on video out. - Real time RAM preview in Adobe After Effects, Apple Shake, Apple Motion and Discreet Combustion. - Super high quality 64 bit RGB codec, Quicktime rendering at trillions of colors in Adobe After Effects. - SDI compliane with SMPTE 292M, SMPTE 259M, SMPTE 296M and ITU-R BT.656 - HD format support: 1080 lines at 23.98PsF, 24PsF, 25PsF, 30PsF, 50i, 59.94i, 60i, 720 lines at 50p, 59.94p and 60p. SD format support: NTSC, PAL, S-Video. - Supports 4:2:2 YUV and 4:4:4:4 RGB colorspace. - Package includes Decklink Card, breakout connector cable. - Product features are different between platforms and software updates.[/FONT]
