Bezier handles ?
onedog
Hey everyone,
How do I turn my key frames in the volume track back to non Bezier handles ? Dont even know what i did to make them Bezier in the first place!
Thanks for your help
Glenn
On the left, of your audio track. Just hit the vol button. There are 3 options. Off, Volume, and Pan. If you are on Volume and hit it again, you get pan. Click it once more and you will turn it off.
I think that is what you are asking.
Later,
Jason
Hey thanks, I've got that but when I make key frames, instead of getting a straight line from one to another I get a Bezier curve. I've seen a tutorial on Bezier handles in Pro 4 but I cant find it anywhere. Very frustrating.
Sounds like your node display is set to Log and not Linear. It's in the settings somewhere on the lower-right in Timeline I think?
onedog
go to your menu bar, click on SETTINGS>APPLICATION SETTINGS -a dialog appears, on the left side choose TIMELINE , the right side shows the timeline options. go to WAVEFORM , you have 2 options, Log(db) or Linear (%). Choose LINEAR. it gives you straight lines. the log gives you the curves which I find hard to control.
Hope that helps.
Ted
FYI guys, the Log/Linear affects only the display of the line. The actual change in volume is the same in either view.
