Better HSL plug-in?
Namcoking
I'm want to adjust the saturation of individual color channels. The HSL plug-in I have with Vegas does not do this. Is there a better HSL plugin out there?
I used to use that plugin quite a bit until one day I was recieving all sorts of errors when trying to render out some footage, turned out it was the plugin causing the problems, as soon as I dissabled that plugin all of the render problems went away. While it's a usefull plugin be aware that if you are having sudden problems with vegas, it could be the plugin causing them.
