IRecordThings
I own an HDC-SD9. It gets the job done for the short YouTube videos I do, but I’m planning on shooting my first feature film over the summer, where the image needs to hold up just as well on a theater screen as it does online.
Previously, I was set on purchasing an HPX170 for the shoot, but that would necessitate the additional purchases of [a] P2 card(s), and probably a new tripod (currently have a Manfrotto 3001BN + 700RC2 head, which I could probably get away with, but I’ve used a DVX on them and it’s an awkward combo).
But then I discovered the Atomos Ninja/Samurai, and thought, hey, for a fraction of the price I could keep the camera and tripod I already have, and just upgrade the image quality—seems like a no-brainer! But I still have a couple questions, namely:
- Since they’re both intra-frame 4:2:2 at that point, would Ninja ProRes compare well to native DVCPRO HD? Do the 2× larger sensors on the HPX necessarily topple the scales in its favor, or could the HDC keep up given sufficient lighting?
- The HDC is obnoxiously locked into ”Digital Cinema Color” (Panny’s name for the xvYCC color space) when set to 24p mode. As you may know, xvYCC support is nonexistent in today’s NLEs; the only way to see it is to plug the camera/card directly into a supporting TV/receiver via HDMI—otherwise the extra color information is ignored and it falls back to Rec.709, and the image looks clipped. How does the Ninja handle this color space? Would it be perserved, stripped out, or converted via rendering intent?
- I saw in another post by Barry that recording to an external recorder isn’t worth it for the HPX because it already uses a high-quality codec and the SDI-Out is only effectively 8-bit; do the advantages of using a Ninja/Samurai similarly diminish across the board as it’s used with better cameras? For instance, is there as big of a quality jump doing HMC150 + Ninja as HDC-SD9 + Ninja?
