rocketguy2
Trying to optimize workflow using CS4. Once I edit a project in Premiere, I link it to After Effects, add fx and color correction, then render out of AE.
Regarding audio, however, what's the best way to clean up tracks and master a sequence? I started bringing clips into Soundbooth prior to editing and removing noise, setting levels, etc. I guess I could then balance the complete edited sequence using the audio mixer in Premiere? Is it possible to treat the Premiere project as a mulittrack in Soundbooth and do all the audio tweaks there? Just not sure which approach is best here.
Thanks!
Thanks!
