use the widescreen filter but unless your framing is perfect, do not apply to a nested sequence. better to apply to each clip so you can adjust the frame up and down as needed. then on output you can either leave the letterbox or crop it out for native 2.35:1.
Problem with adding the widescreen filter on a clip by clip basis rather than to a sequence is you'll have color correction inconsistency from shot to shot. Better to apply once to an entire sequence.
-Noah
