thematthewbone said:garageband on a MAC is really your only option.
not to much in the PC realm at the moment to compare to it.
triplej96 said:I think this belongs in this forum...
I'm no John Williams by all means as a matter a fact I'm a novie when it comes to music. What would you guys sugges the best soundtrack scoring software that is atleast somewhat user friendly?
Thank You,
Josh
Matt Grunau said:Best software? Cubase. End of discussion.
Cubase is great software, and for music creation, could be all you need. It can use VST plugins and instruments. It's fairly pricey and so are some of the virtual instruments like Groove Agent and Virtual Guitarist, but once you get it and start using it, you'll never switch to anything else. Factor that in with Wave Lab, and a mind blowing array of filters, and you have everything you need at your disposal.
Reason is damn fine also, but is not as flexible for doing work where you need to record vocals or do multitrack work. But for doing sampling, drum based, and techno stuff as well as atmospheric music, Reason is king.
Both Cubase and Reason are great programs, and being able to use ReWire and have them both running at the same time is awesome.
Check this out:
http://www.steinberg.net/687_1.html
Listen to some of the demos. For 800 bucks, that is a steal. 27 gigs of samples? One job and it pays for itself.
Anyone who insists you need to use a Mac to do "Pro Audio" or "Music" is flat out wrong. Last time I checked, 1's and 0's are the same, and when you get down to the digital level with prerecorded samples like the so many instrument packs, they are all alike.
Matt Grunau said:If you can find cheaper software that will allow VST instruments, that Orchestra pack could still be worth it.
