avr said:Hi i´m currently working is HDV 50i project. The natural way to show the video will be a pal tv (I´m a pal customer)
The question is. Which is the best way to export (AE 7) HDV video to pal widescreen tv? any suggestion?
thanks
surf said:why do you want to render in AE?
I wouldn't do the final render in AE. I would export as uncompressed, and then I would set the sequence in Premiere, and I would render there. What kind of format do you want? HD-DVD, DVD, VHS, DV cassette? Choose the format and then we can help more. Although your TV is not HD, I would export it as HD, because later you may buy a new telly.
avr said:DVD will be the final way to see the video. I was thinking in export to a TIFF sequence and open it in vegas and render to mpg2...
is this better than export in AE7 as a HDV 50i project and open in vegas 6 and render to mpg2 (DVD) ?
thanks
Rapier_100a said:Again, it depends on the length of the video. If you are going to export as an image sequence, thing about .png or .tga, both of which can use a degree of losless compression.
