Best Setting to use for Adobe Encore CS5? ''1920 by 1080 30p NTSC'' ''DVDR''
flatlander
Hey There I shot some hd clips at 1920 by 1080 30p NTSC and i exported them out of FCP as a self contained quicktime file uncompressed and i am using Adobe Encore CS5 to build the dvd with and i would like to know the best setting to use with dvdr ? Thank you
I think you're going to find all the settings not very satifactory because the mpeg-2 encoder in Encore isn't the greatest. However if you don't have a budget to hire a compressionist try these settings:
More info here: http://www.dvxuser.com/V6/showthrea...-first-if-you-re-lost-Best-encoding-Practices
  • Highest Quality: 2-pass VBR Video low 1.5mbps, video avg 7mbps, video peak 9.0 mbps, Audio Dolby Digital at 384kbps. This will yield about 1.2 hours on a single layer DVD.
  • If you are encoding DV material, set your fields to Lower (or Odd).
  • Always keep the source framerate.
