Hi Alohype,
check out this event video I made, using the fs700 with 7Q.
https://vimeo.com/124663980
Password: joza
if you like it, here are the settings.
Slog2, 2000 ISO default, 4K>HD on 7Q. However, because it was so, so low light (only low wattage practicals from the ceiling fans and streetlights, I switched th camera from ISO to Gain, and with the low, medium, high switch I programmed +3, +6 and +12db gain. Now beware, this footage came out super noisy so I had to run it through NR (Neatvideo). This is noticeable and not always my preferred method. But when it's the difference between getting the shot and not getting it, I'll gladly take noise reduction on these event types of situations.
Ah, I shot with a Nikkor 28mm AIS on a speedbooster. This helped out as well.
Best of luck with your shoot tonight. I hope this helps. I'm sure others might chime in with better advice too!
Many thanks for your reply!I do not have 7Q and as far as I remember some people were advising to use Cine profile for low light. Slog2 internally can be a pain to get it right in post :/
