Best macro option...
djembeplay
Hey everyone,
I didn't see this one specifically in any past threads through searching so I figured I would give it a shot.
I want to get some nice reaaallly close-up shots. The stock DVX lens just isn't cutting it for me. What is my best option here? I can't seem to find any '72mm macro lens' attachments on b&h... so I guess such a thing doesn't exist. Any ideas?
Thanks.
A close up filter might help, they have come in quite handy for me while shooting photos of Lego. They're just a filter rather than a lens. After a quick Google search, I found this. Not sure if that exactly what you were looking for, but it may work.
BLAM
Believe it or not, you can get some relatively high quality shots from those. I bought the one that come's with 4 lenses.
Case in point:
Hey guys-
Sorry, I know I'm a slow one to respond. I don't frequent this site much these days.
Anywho, thanks a ton for the info-- this is exactly what I was looking for actually. I searched for "72mm macro lens" on B&H. Now I know I didn't get any results because I used the word "lens".
So this is probobly the only option for DVX/HVX owners besides a 35mm adapter with fixed lenses, right?
That's a close up diopter and is in fact a lens. (it has a power) Optical filters are plano (flat) and to not have an optical power be it positive or negative.
Hey,
rcbrown23... I did click on your link. I'm guessing you are asking whether I did or not because I wrote "So this is probobly the only option for DVX/HVX owners...". By this I meant are filters in general the only option... not just one specific filter. Sorry for being unclear. Anyways, the package in the link you sent looks great. Thanks.
Curiously enough, I just found out that even a search for "72mm macro filter" doesn't return any results at b&h either... sooo... I'm guessing these must be pretty uncommon then since b&h is like the 'we have everything ever made for any camera' store.
Chuck - what do you think would yield a closer and/or sharper result... a diopter or a plano filter?
Thanks again.
Optical filters are just that. They change the amount or quality of the incoming light that the camera is seeing. They have nothing to do with changing the power of the taking lens. They don't make for closer focusing or wider or longer focal lengths.
If you want to make camera lens focus closer you either need to use an extension tube between the camera and the lens (not a viable option in your case) or a close up diopter mounted on the front of the lens. By the way diopters can be stacked in groups to provide different amounts of image magnification. Diopters come in two different configurations, single element (simple lens) or achromatic (a double element generally cemented togeather group). The achromatic types can provide higher optical quality (less color fringing and curveture of field) albeit at a higher cost.
if you want a high quality 72mm achromat for closeups, check out the one redrock sells for their adapter or the brevis one. both are great... i have the redrock one. here is a still from the hvx with the redrock achromat. note: this is not with the m2 35mm adapter. just hvx+achro. the shallow depth comes with the achro...
Hey-
Alright, thanks a ton for the info guys.
Incidentally, what do people use when you see extreme close-ups (for example, the entire screen occupied by the wing of a fly)?
they would probably use a really nice lens on a really nice camera...
but im only posting because im confused. i thought a diopter enabled you to focus on two different planes? i thought it was one of those double lens thingys or whatever i really dont know what im talking about!! is diopter just a name for a device that attaches to the front of the camera?
