Best DV Compression Software ?
Thistlebop
Sorry to bother everyone, but I'd love to get as many opinions on which Compression software works the best for compressing "Avi's" for web viewing.
--Bop
Hoping with anticipation that some of the guru's will chime in. ;D
Re: Best DV Compression Software ?
If you've got money to spare Sorenson Squeeze 4 is great. If you're on a budget then jump over to www.doom9.org. They've got tons of guides for video compression and most of it uses open source or free software.
On a side note, I wouldn't use AVI for web compression. I'd look at Windows Media, Quicktime, or Shockwave Flash.
Hope that helps.
Chris
[quote author=krestofre link=board=dvd;num=1099519622;start=0#1 date=11/03/04 at 14:48:36]If you've got money to spare Sorenson Squeeze 4 is great. If you're on a budget then jump over to www.doom9.org. They've got tons of guides for video compression and most of it uses open source or free software.
Hope that helps.
Chris[/quote]
Actually I ment that my original clips were "Avi's". Do I need to change them to another format before converting them for WM, QT or Flash ? And outta the three... which one is most widely used around here ?
--Bop
Yea, I like Quicktime. WM is my other favorite. I am forever flopping between the two.
[quote author=Thistlebop link=board=dvd;num=1099519622;start=0#3 date=11/03/04 at 18:23:34]original clips were "Avi's". Do I need to change them to another format before converting them for WM, QT or Flash?[/quote]
No, you should be able to convert directly from the AVI. But, an AVI can be compressed or uncompressed. Normally AVIs created through captures are created uncompressed.
As for the popular format around here, that would be Quicktime (mov) and then Win Media Player (wmv). Creating one of each will generally cover everyone and keep people happy :)
Try this free encoder out - it now takes avi's(and avs scripts)
QuEnc
Have fun,
Tin2tin
I've been practicing some with Sorensen's Squeeze. The problem that I'm having is that I can't seem to keep the size and quality that I want without the file still being a Gross 10 Megs >:(
I want to get it down to 3 megs or less so that people will take the time to download it and view it. But when I get it down to that size, the images are the size of a postage stamp (slight exageration, but you get the point).
Arrrrgh >:(
--Bop
How long of a video are your trying to compress? Depending on that answer you may be asking the impossible. Also, which of the three formats that we've discussed are you using as output?
A 10 MB file is not all that bad this day and age. The new Star Wars trailer was 10 MB. Not that it has a lot to do with this discussion, but I thought I'd mention it. ;D
Chris
Re: Anybody caw this movie...
I agree with Krestofre, we are not in the age of carbon computer, 10 MB file today is not that much.
I average about 2MB per minute on a 320X240 video clip. This gives me adequate quality / file size.
On this subject, I'm trying to export a 15 min. project for the web using compressor (to mpeg-4) and my file is about 65 megs, but it's only 320x240 size and I still see some digital noise on some parts (the dvd version is beautiful and clean). I watched "Roadside Attractions" in the Screen grabs/clips area and his clip was 16:9 size, large and clean. Yet it took about the same amt. of time to download as mine (about 5 or 6 mins. on dsl/cable). Am I missing something? Can I make mine larger and cleaner while producing a smaller file?
Any help would be appreciated
Nathan
Just checked the "Roadside Attractions" site again and I was wrong. His medium size one is actually smaller than mine, so I figure the larger one (which isn't available b/c of bandwith limits) is probably about the same size. I also checked another one that I had on my mind when I wrote the last post and realized that he had just re-sized it to 720x320, that's why it was so wide.
Nathan
