Best Config for New DVX100a
prauphet
Hello All,
I've finally decided on purchasing the DVX100 but I'm not sure where to start with the accessories. I've found matteboxes and follow-focus add-ons, not to mention the 16:9 adapter but I'd like to find out from the community what you consider must haves and things I can wait on.
At this point B&H has a good starter package at around $4500 before rebate. I'm considering adding on the mattebox for sure but as for the rest?
I appreciate your thoughts. I have some projects coming up so I need to make a decision this week!
Thanks for your thoughts,
rory
The Barry Green DVX Book is a must have accessory -- and, probably the only accessory worth owning this early on. Here is the deal. Every shoot requires specialized gear which is really expensive to buy. Considering you're a noob, I'd say get the camera and a good tripod ($500-$2K). Then, put back a Grand for anything else you decide you need later on. The anamorphic is a lot of trouble, but with a lot of effort can produce excellent widescreen results. As an owner of a matte box and follow focus, I'd say wait. Get those things once you discover you have a need for them. Or, if this is merely a consumer pursuit, buy whatever you want and put it on the top shelf of the curio in your dining room. EVSOnline.com supports this message board and for anything DVX-related, they are the better dealer. Good luck and welcome to DVXUser. :thumbsup:
In order:
0. UV or clear filter
1. Tripod with 503 head (or better).
2. Decent shotgun (AT897 was my choice)
3. Extra batteries
4. Senn G2 wireless mic kit with buttplug.
5. Wired lav (Countryman B3 was my choice).
6. Pelican Case (or other)
7. Polarizing filter
Forget the mattebox, anamorphic, follow focus and other fancy stuff unless you have a specific need for it.
Here is my kit:
http://www.VeniceDigitalVideo.com/locationDVXkit.htm
I agree with the last post (mostly).
In my opinion it is necessary to buy at least 1 extra longlife battery
That would be my first purchase.
I agree with the uv filter too (I prefer UV/Haze to clear), a shotgun mic (I like my AT897) and a camera bag.
Everything else can wait.
Most people talk about needed a good tripod. But for my 2 cents, I haven't loved any of the ones I have used for under $1500. so, I would rent a GOOD one (as needed) rather than buy an OK one. You can get away with a cheap set of sticks if you are not trying to do moves.
All of the the other toys you should buy when you actually need them. And, consider renting certain items before investing. But, it all depends on your budget and the type of shooting you are doing.
All the best.
I agree with renting the products if possible before purchasing. Also, I suggest getting the AT897 for a mic, a UV lens, extra batteries, and some lights.....
